Roaming profiles and mac osx
I’m seeking for some help in setting up roaming profiles for mac osx client (I’m testing with 10.15.2).
I’ve made several test after looking at the documentation (more exaustive for win clients) and many discussion in the forum, but nothing I did seems working.
Actually, mac clients can correctly join the domain (and I can see them in computer management) and user logins are working smootly.
Clinet side (on mac osx), I configured them to create a mobile account on login and selected the option “Use UNC path from Active Directory to derive network home location” (with protocol smb:)
First question: is this possible with mac?
Then, how to?
Probably I’m missing something or did something wrong.
Can some one drive me through a correct configuration?
Thank you in andvance!
Hi Gabriele,
as far as I know, you are able to mount your personal share and others while you login on different macs.
You will not have roaming settings, like desktop, mail, calender etc.
Christian
