Reuse containername nested with containername that exist with ansible modules
I’m a little unsure whether this is a feature or a bug. Creating containers whose names have already been used in the LDAP structure is apparently not possible with the Ansible module univention_directory_manager.
Example Code Playbook:
- name: Test nested policy container
  hosts: primary
  become: yes
  vars:
    ucs_ldap_base: dc=example,dc=test
  tasks:
    - name: container BBB in root
      univention.ucs_modules.univention_directory_manager:
        module: "container/cn"
        state: "present"
        position: "{{ ucs_ldap_base }}"
        set_properties:
          - property: name
            value: "BBB"
    - name: container AAA
        state: "present"
        position: "cn=policies,{{ ucs_ldap_base }}"
        set_properties:
          - property: name
            value: "AAA"
          - property: policyPath
            value: "1"
        state: "present"
        position: "cn=AAA,cn=policies,{{ ucs_ldap_base }}"
        set_properties:
          - property: name
            value: "BBB"
            value: "1"
The third container under AAA is not generated, if I remove the first Ansible task it is generated.
Any hint ?
UDM commands work as expected.
