Replace SSO-Certificate
Dear Support
Due to our implementation of Office 365, we need to replace the SSO-SSL Certificate. Reason is, that we need a registered Certifiate.
Is there any documentation on how to change the Certificate?
Additionally, we like to know, if it’s possible, to have a wild-card certificate implementation…
Many thanks in advance for your help
Regards
STAR AG
could you please show your UCS version, since 4.2 erratum 170 you can configure those settings per ucr variable (http://errata.software-univention.de/ucs/4.2/170.html).
best regards
bytemine GmbH
Hi bytemine
The currently installed version is: UCS Version 4.2-2 errata 198
Is there no manual for this? haven’t found it…
Regards
STAR AG
Mastodon
