We are getting prompted to install Software Updates in the UCS Management GUI. However we have applied the updates and rebooted. It goes away, but comes back a short time later for the same update.
The update is for Horde.
It also re-appears when updating via the command line…no matter how many times we run it this shows up…
The most current version of the Horde app is 5.2.7-3. The UCRV “appcenter/apps/horde/version” should show this.
The repository settings are inside the container and can be displayed with
i think this is a problem with the horde app itself. The reason was a buggy update script in the app. This should be fixed now (hopefully). You have to update the appcenter cache (univention-app update) and run univention-upgrade two times to check if it is working correctly now.
-> univention-app update
-> univention-upgrade
Checking for package updates: none
Checking for app updates: none
