gestern habe ich versucht auf unserem Univention UCS-Server Relution von der Vorversion auf 5.17.3 zu aktualisieren.
Leider schief gegangen.
Lt. Systemctl läuft relution:
root@ucs1:~# systemctl status docker-app-relution
● docker-app-relution.service - LSB: Start the Container for relution
Loaded: loaded (/etc/init.d/docker-app-relution; generated)
Active: active (exited) since Tue 2023-06-27 08:06:35 CEST; 35min ago
Tasks: 0 (limit: 4915)
Memory: 0B
CGroup: /system.slice/docker-app-relution.service
Jun 27 08:06:32 ucs1 systemd[1]: Starting LSB: Start the Container for relution...
Jun 27 08:06:35 ucs1 docker-app-relution[2965]: Starting relution Container 6b0fe4f3102a6d473734e7edc3d581619e0d82871786d93c881140459fb2aed6 ....
Jun 27 08:06:35 ucs1 systemd[1]: Started LSB: Start the Container for relution.
(univention-app status relution gibt das gleiche aus)
lt Apache Error-Log antwortet der lokale Webserver von Relution aber nicht auf Anfragen (Hostname durch EXAMPE ersetzt):
[Tue Jun 27 08:00:40.524020 2023] [proxy:error] [pid 31171] [client 192.168.200.191:64455] AH00898: Error reading from remote server returned by /favicon.ico, referer: https://mdm.EXAMPLE.de/
[Tue Jun 27 08:06:45.505356 2023] [proxy_http:error] [pid 31122] (104)Connection reset by peer: [client 192.168.200.191:64498] AH01102: error reading status line from remote server 127.0.0.1:40005
[Tue Jun 27 08:06:45.505405 2023] [proxy:error] [pid 31122] [client 192.168.200.191:64498] AH00898: Error reading from remote server returned by /
[Tue Jun 27 08:36:16.056586 2023] [proxy:error] [pid 31126] (111)Connection refused: AH00957: HTTP: attempt to connect to 127.0.0.1:40005 (127.0.0.1) failed
[Tue Jun 27 08:36:16.056677 2023] [proxy_http:error] [pid 31126] [client 192.168.200.191:64693] AH01114: HTTP: failed to make connection to backend: 127.0.0.1
die Ausgabe von docker logs 6b0fe4f3102a6d473734e7edc3d581619e0d82871786d93c881140459fb2aed6 gibt dieses zurück:
INFO: Source pre-run script from /var/lib/univention-appcenter/apps/relution/conf/unset.sh
INFO: Pre-run script from /var/lib/univention-appcenter/apps/relution/conf/unset.sh sourced
Install MariaDB client... using DNF
No repository match: AppStream
AlmaLinux 8 - BaseOS 3.5 MB/s | 3.9 MB 00:01
AlmaLinux 8 - AppStream 4.7 MB/s | 11 MB 00:02
AlmaLinux 8 - Extras 21 kB/s | 18 kB 00:00
MariaDB Server 226 B/s | 327 B 00:01
Errors during downloading metadata for repository 'mariadb-main':
- Status code: 404 for https://dlm.mariadb.com/repo/mariadb-server/10.7/yum/rhel/8/x86_64/repodata/e3833871afca2d811714f593ca811a49aa164403fe90dce8fa162127d4accbaa-updateinfo.xml.gz (IP: 104.18.135.24)
- Status code: 404 for https://dlm.mariadb.com/repo/mariadb-server/10.7/yum/rhel/8/x86_64/repodata/222709914d36d4a0fd607616111adc273a0822b3d990597747cb4aac88c80396-primary.xml.gz (IP: 104.18.135.24)
- Status code: 404 for https://dlm.mariadb.com/repo/mariadb-server/10.7/yum/rhel/8/x86_64/repodata/87f4cced936ba0b45379e14a9a76e20837bdffcfff567065bc344e9af1fb6e4c-filelists.xml.gz (IP: 104.18.135.24)
Error: Failed to download metadata for repo 'mariadb-main': Yum repo downloading error: Downloading error(s): repodata/87f4cced936ba0b45379e14a9a76e20837bdffcfff567065bc344e9af1fb6e4c-filelists.xml.gz - Cannot download, all mirrors were already tried without success; repodata/e3833871afca2d811714f593ca811a49aa164403fe90dce8fa162127d4accbaa-updateinfo.xml.gz - Cannot download, all mirrors were already tried without success; repodata/222709914d36d4a0fd607616111adc273a0822b3d990597747cb4aac88c80396-primary.xml.gz - Cannot download, all mirrors were already tried without success
/relution-docker.sh: line 169: mysql: command not found
/relution-docker.sh: line 179: mysql: command not found
MariaDB Server 273 B/s | 327 B 00:01
- Status code: 404 for https://dlm.mariadb.com/repo/mariadb-server/10.7/yum/rhel/8/x86_64/repodata/87f4cced936ba0b45379e14a9a76e20837bdffcfff567065bc344e9af1fb6e4c-filelists.xml.gz (IP: 104.17.191.14)
- Status code: 404 for https://dlm.mariadb.com/repo/mariadb-server/10.7/yum/rhel/8/x86_64/repodata/e3833871afca2d811714f593ca811a49aa164403fe90dce8fa162127d4accbaa-updateinfo.xml.gz (IP: 104.17.191.14)
- Status code: 404 for https://dlm.mariadb.com/repo/mariadb-server/10.7/yum/rhel/8/x86_64/repodata/222709914d36d4a0fd607616111adc273a0822b3d990597747cb4aac88c80396-primary.xml.gz (IP: 104.17.191.14)
MariaDB Server 284 B/s | 327 B 00:01
MariaDB Server 294 B/s | 327 B 00:01
MariaDB Server 305 B/s | 327 B 00:01
MariaDB Server 317 B/s | 327 B 00:01
Folglich kann der Maria-DB-Client nicht geladen werden - wobei mir nicht klar ist, ob das ein Problem vom relution-Docker-Image oder von Univention ist.
Wie kann ich das hier korrigieren?
Danke und viele Grüße,
Christoph
