QEMU verhindert Upgrade
ich wollte gerade auf einem UCS das aktuelle Upgrade auf 4.2 einspielen. Dort läuft ein Windows7 in einer VM welches wohl das Upgrade verhindert. Im Log:
15.07.17 11:53:39.014 DEBUG_INIT
**** Starting univention-updater with parameter=['/usr/share/univention-updater/univention-updater', 'net', '--updateto', '4.2-1', '--ignoressh', '--ignoreterm']
Version=4.1
Patchlevel=4
starting net mode
--->DBG:update_available(mode=net, cdrom_mount_point=/media/cdrom, iso=None)
Checking network repository
Update to = 4.2-0
**** Downloading scripts at Sat Jul 15 11:53:44 2017
**** Starting actual update at Sat Jul 15 11:53:49 2017
Running preup.sh script
Sa 15. Jul 11:53:49 CEST 2017
HINT:
Please check the release notes carefully BEFORE updating to UCS 4.2-0:
English version: https://docs.software-univention.de/release-notes-4.2-0-en.html
German version: https://docs.software-univention.de/release-notes-4.2-0-de.html
3rd party components.
Do you want to continue [Y/n]?
Custom preupdate script /var/lib/local-preup.sh not found
Checking for space on /var/cache/apt/archives: OK
Checking for space on /boot: OK
Checking for space on /: OK
Checking for package status: OK
Checking LDAP schema: 5969e62d OVER: Loading Translog Overlay
5969e62d OVER: db_init
5969e62d OVER: Configuring Translog Overlay
5969e62d OVER: Configured Translog Overlay to use file "/var/lib/univention-ldap/listener/listener"
5969e62d OVER: db_close
5969e62d OVER: db_destroy
OK
ERROR: Found QEMU virtual machines using old machines
Virtual machines using old QEMU virtual machine configurations may experience
reboot problems and should be upgraded.
See for more information.
This check can be disabled by setting the UCR variable 'update42/qemu' to 'yes'.
Error: Update aborted by pre-update script of release 4.2-0
Woran liegt das?
Gruß Sven
Ich denke mal das spielt auf diesen SDB-Artikel an. Der Link dazu fand sich übrigens in den Release-Notes :wink:
