1. What is Kubernetes?
Kubernetes (often called K8s) is an open-source system for managing containers (like Docker). Think of it as an orchestra conductor: it makes sure all your applications (containers) run where they should, scale up when needed, and stay healthy.
2. Why use Kubernetes?
- Scalability: Automatically add or remove resources depending on demand.
- Reliability: If something crashes, Kubernetes restarts it.
- Portability: Runs on cloud, on-premises, or hybrid environments.
- Efficiency: Uses resources more effectively than manual deployment.
3. Key Concepts
Here are the main building blocks of Kubernetes:
Cluster
A group of machines (servers) that run your applications. -
Node
A single machine inside the cluster. It can be physical or virtual. -
Pod
The smallest unit in Kubernetes. A pod usually runs one container, but it can hold multiple tightly connected containers. -
Deployment
A set of instructions that tells Kubernetes how to run and manage pods (e.g., “run 3 copies of this app”). -
Service
A stable network address to connect to your pods, even if they move around between nodes. -
Namespace
A way to organize resources into separate “folders” within the cluster.
4. How Kubernetes Works (Simple View)
- You define what you want (for example: “run 5 copies of my web app”).
- Kubernetes schedules pods on available nodes.
- If a pod fails, Kubernetes restarts or replaces it.
- If demand increases, Kubernetes scales up automatically.
- Networking and load balancing are handled in the background.
5. Typical Workflow
- Write a manifest (usually a
.yamlfile) that describes your app. - Apply the manifest with
kubectl apply -f file.yaml. - Kubernetes creates and manages the resources.
- You can check status with
kubectl get podsorkubectl get services.
Want to go deeper? Check out the follow-up guide: “Next Steps in Kubernetes – From Basics to Practice”, where we cover kubectl commands, writing simple YAMLs, scaling, and monitoring.
