Question
Is it supported to mirror the appcenter for airgapped environments
Answer
It is only supported to mirror the UCS repository, the appcenter itself cannot be mirrored. While it’s possible to simply copy the appcenters content by wget --mirror, various applications are relying on containers stored on artifacts.software-univention.de. While docker supports pull-though mirrors, they are not meant for air-gapped environments and similar use-cases.
