UCS in a virtual environment
Question
Is it possible to create a user under ucs@school with the role “school administrator” for each school?
Answer
Yes it is, with the following UCRV.
If you are using the default UCRV (univention-config-registry-variables) so you have the options to create the following user for ucs@school : student, teacher, staff, teacher and staff.
If you keep the following UCRV empty, now you have the option to create an ucs@school admin just for the each school:
ucsschool/wizards/schoolwizards/users/roles/disabled: schoolAdmin
Comma-separated list of UCS@school user roles, that shall be disabled in UCS@school user wizard (Default: schoolAdmin; possible values: student,teacher,staff,teachersAndStaff,schoolAdmin)
So you have to use this command below:
ucr set ucsschool/wizards/schoolwizards/users/roles/disabled=
Now you have the option like in the picture below
