QA: How to configure Veyon in OOBE Szenarios
Question
In OOBE Szenarios / test environments it’s possible that the same image has to be used for several different environments thus having different veyon-cert.pem’s. How can this be achieved, without having to manually configure the authentication using the GUI?
Answer
You can simply configure all different required settings for your image in Veyon, and enter the OOBE mode afterwards. In the deployment (e.g. with OOBE scripts, Cloudbase-Init or similar) you can simply copy and import the key afterwards with the following command:
‘C:\Program Files\Veyon\veyon-cli.exe’ authkeys import teacher/public C:<your deployed key>
