Hi, I wonder if I might ask for a gentle poke in the right direction.
I’m looking at using Univention-Core as a basic domain controller to take over this role at a small site running an old SBS server.
I’ve reviewed doc hints online → 9.3. Migrating an Active Directory domain to UCS using Univention AD Takeover — Univention Corporate Server - Manual for users and administrators
and I think I am starting off on the wrong foot / or at least I have mistaken understanding of the expected starting point
- clean install of UCS in a modest sized VM
- install goes smoothly, boot up, and quite early I am asked to choose from 3 scenarios
- (1) create new UCS domain
- (2) join exist UCS domain
- (3) Join exist MS_AD Domain
I kind of assumed “hah, I wanted number 3 since we are going to join the exist domain, then do the take over / harvest data and roles from that DC to this DC, then promote the roles / take control of domain / etc.”
After kind of trying to poke in that direction, the process fails, and I think the errors hinted to me that I create a chicken-egg problem with the path I chose.
ie, cannot do takeover if you are already member of domain (?)
so possibly can someone suggest/confrim
assuming I am on a clean UCS instance (ie, I will dump my failed attempt and do a clean fresh install again)
I get hostname assigned fine and DNS from local DNS-DHCP (ie, running on the existing legacy sbs DC)
then I should choose ?which of the 3? options regarding UCS “Domain setup” - do I want to pick “option1, new UCS domain” - let it proceed. Then install the “Domain Takeover” module - then kick off process - it will do all the things it wants to make for successful trajectory?
Sorry for having such a basic question, I hope this makes sense. The docs sort of don’t talk about “here is where you are starting at ground zero” so much as they assume? you are in a ‘good place to start’ - and I am simply not clear what this might actually be.
thank you!
Tim
