Q&A: Will my empty class be deleted automatically?
Question:
Answer:
No, in principle, classes are “only” groups, so a group is retained if you remove the users.
To find empty classes you can use these filters:
Replace OU in the first command
univention-ldapsearch '(&(!(uniqueMember=*))(!(memberUid=*)))' -b cn=klassen,cn=schueler,cn=groups,ou=<OU>,$(ucr get ldap/base) 1.1
or
univention-ldapsearch '(&(!(uniqueMember=*))(!(memberUid=*))(objectClass=ucsschoolGroup))'
