Question:
How can a crt certificate be converted to the windows pfx|p12|pkcs12 format?
Answer:
You can just use openssl to do the job for you.
Choose the extension that fits your need, the file formates are all the same.
1. without the private key
root@ucs:~# openssl pkcs12 -export -out ucsCA.pfx|p12|pkcs12 -in /etc/univention/ssl/ucsCA/CAcert.pem \
-nokeys
2. including the private key
-inkey /etc/univention/ssl/ucsCA/private/CAkey.pem -passin "pass:$(cat /etc/univention/ssl/password)"
Check the generated certificate
Finally you should check the generated certificate before using it.
root@ucs:~# openssl pkcs12 -info -in ucsCA.pfx|p12|pkcs12
