Q&A: How can I Identify shipped Packet Versions with UCS Versions?
Question
Answer
You can use the apt-cache command to see what versions are available for what UCS version. See the following example for samba. You will see a line with the version number of Samba followed by a link with the repository of UCS including version number.
In this example we see Samba version 4.6.1 has been initially shipped with UCS 4.2-0.
root@master431:~# apt-cache policy samba
samba:
  Installiert:           2:4.7.8-1A~4.3.0.201808081836
  Installationskandidat: 2:4.7.8-1A~4.3.0.201808081836
  Versionstabelle:
 *** 2:4.7.8-1A~4.3.0.201808081836 500
        500 https://updates-test.software-univention.de/4.3/maintained 4.3-2/amd64/ Packages
        100 /var/lib/dpkg/status
     2:4.7.5-1A~4.3.0.201803140017 500
        500 https://updates-test.software-univention.de/4.3/maintained 4.3-0/amd64/ Packages
     2:4.6.1-1A~4.2.0.201803051359 500
        500 https://updates-test.software-univention.de/4.2/maintained 4.2-4/amd64/ Packages
     2:4.6.1-1A~4.2.0.201711161303 500
        500 https://updates-test.software-univention.de/4.2/maintained 4.2-3/amd64/ Packages
     2:4.6.1-1A~4.2.0.201707121156 500
        500 https://updates-test.software-univention.de/4.2/maintained 4.2-2/amd64/ Packages
     2:4.6.1-1A~4.2.0.201706150016 500
        500 https://updates-test.software-univention.de/4.2/maintained 4.2-1/amd64/ Packages
     2:4.6.1-1A~4.2.0.201703291823 500
        500 https://updates-test.software-univention.de/4.2/maintained 4.2-0/amd64/ Packages
     2:4.5.1-1.864.201709151857 500
        500 https://updates-test.software-univention.de/4.1/maintained 4.1-5/amd64/ Packages
     2:4.5.1-1.848.201611070734 500
        500 https://updates-test.software-univention.de/4.1/maintained 4.1-4/amd64/ Packages
     2:4.3.7-1.835.201607051244 500
        500 https://updates-test.software-univention.de/4.1/maintained 4.1-3/amd64/ Packages
     2:4.3.7-1.830.201604110947 500
        500 https://updates-test.software-univention.de/4.1/maintained 4.1-2/amd64/ Packages
     2:4.3.3-1.812.201512111459 500
        500 https://updates-test.software-univention.de/4.1/maintained 4.1-1/amd64/ Packages
     2:4.3.1-1.798.201511131318 500
        500 https://updates-test.software-univention.de/4.1/maintained 4.1-0/amd64/ Packages
     2:4.2.3-1.832.201603071547 500
        500 https://updates-test.software-univention.de/4.0/maintained 4.0-5/amd64/ Packages
     2:4.2.3-1.795.201510081809 500
        500 https://updates-test.software-univention.de/4.0/maintained 4.0-4/amd64/ Packages
     2:4.2.3-1.758.201507271307 500
        500 https://updates-test.software-univention.de/4.0/maintained 4.0-3/amd64/ Packages
     2:4.2.0~rc2-1.729.201503191909 500
        500 https://updates-test.software-univention.de/4.0/maintained 4.0-2/amd64/ Packages
     2:4.2.0~rc2-1.717.201501091014 500
        500 https://updates-test.software-univention.de/4.0/maintained 4.0-1/amd64/ Packages
     2:4.2.0~rc2-1.708.201411171637 500
        500 https://updates-test.software-univention.de/4.0/maintained 4.0-0/amd64/ Packages
root@master431:~#
Mastodon
