Question:
How can I deactivate saml
Answer:
You can deactivate saml/sso with some ucr varaiblaes:
ucr info umc/web/sso/enabled
umc/web/sso/enabled: true
If this option is activated, the login via single sign-on is tried before the regular login is used.
Categories: management-umc
This prevents the creation of DNS entries:
ucr info ucs/server/sso/autoregistraton
ucs/server/sso/autoregistraton: <empty>
If this variable is set to 'true', this UCS system tregisters its IP address at the fqdn of the identity provider (ucs/server/sso/fqdn). (default: true)
Despite this you should set a valid value for ucs/server/sso/fqdn.
Afterwards re-run the joinscript:
univention-run-join-scripts --force --run-scripts 91univention-saml.inst
