Question
How are Passwords within UCS are encrypted?
Answer
Passwords are usually hashed and stored using SHA-512. The hashing method can be set via the UCR variable ‘password/hashing/method’.
root@ucs:~# ucr info password/hashing/method
password/hashing/method: SHA-512
Selects the hash algorithm to use for saving passwords in the LDAP directory. Possible values are: "MD5": Less secure than the SHA methods, not recommended; "SHA-256": more secure than MD5; "SHA-512": more secure than MD5, recommended. (default if not or incorrectly set: "SHA-512", capitalisation is ignored).
Categories: system-password
Detailed technical Information
The stored Value is salted and contains the following parts (they are separated by $)
$6$mclEwEsVXxmIbwob$iWYNviH9PZgwvdIWdmgsaVKFmVAsNvoIGESkKytCXBXKdE/fE7MZv2KDPGSjBGTxKSBg5.2GOw8azffvpbX2e/
6is the mode → Crypt3 + SHA-512
mclEwEsVXxmIbwob→ the generated Salt
iWYNviH9PZgwvdIWdmgsaVKFmVAsNvoIGESkKytCXBXKdE/fE7MZv2KDPGSjBGTxKSBg5.2GOw8azffvpbX2e/→ the Password Hash itself
