Q&A: Can we use Templates to Deploy UCS Virtual Machines in a quick way?
Question
Answer
Currently this is not possible as the join to an UCS domain is related to the hostname of the new system. Using it as a template would not work.
Workaround
You can install UCS without joining it. Thus you might change the hostname and IP address of a clone and then join to a domain.
