Q&A: Can /var/lib/opsi/ be Removed After Uninstalling OPSI?
Question
After uninstalling OPSI can I remove the directory /var/lib/opsi/` manually?
Answer
Yes, this contains the repository packages which are not needed any longer after uninstalling the app. Re-installing the app later will create these files again.
