Question:
Can I set values with spaces in policies for UCR variables?
Answer
Yes you can. See below example.
Step 1:
Value set as policy in UMC web frontend:
Step 2:
Re-read policy on the server assigned with the policy just created:
root@ucs:~# systemctl restart univention-directory-policy.service
root@ucs:~# ucr dump| grep socke
samba/socket_options: TCP_NODELAY SO_RCVBUF=32768 SO_SNDBUF=32768
Step 3:
Re-write configuration file and check if the parameters are set correctly. Finally restart service:
root@ucs:~# ucr commit /etc/samba/smb.conf
Multifile: /etc/samba/smb.conf
root@ucs:~# grep TCP_ /etc/samba/smb.conf
socket options = TCP_NODELAY SO_RCVBUF=32768 SO_SNDBUF=32768
root@ucs:~# /etc/init.d/restart samba
