Question:
Can I match my clients against their station ID?
Answer
Yes it is possible by adding the following to your clients.conf:
<pre>
elsif ("%{Called-Station-Id}" =~ /:Schule$/ ) {
</pre>
Note: This check is case sensitive.
Option 1: Rewrite all clients to a valid format
To rewrite your clients IDs to a valid format use a new policy by adding the following to raddb/policy.conf:
# Rewrite called station id attribute into a standard format.
rewrite_calling_station_id {
if (Calling-Station-Id =~ /([0-9a-f]{2})[-:]?([0-9a-f]{2})[-:.]?([0-9a-f]{2})[-:]?([0-9a-f]{2})[-:.]?([0-9a-f]{2})[-:]?([0-9a-f]{2})/i) {
update request {
Calling-Station-Id := "%{tolower:%{1}-%{2}-%{3}-%{4}-%{5}-%{6}}"
else {
noop
Option 2: Use regular expressions
clients.conf:
<pre>
elsif ("%{Called-Station-Id}" =~ /:[Ss]chule$/ ) {
</pre>
