Q&A: Anydesk does not work after update
Anydesk
Question
Since an upgrade, accessing the KDE interface via Anydesk no longer works. Anydesk reports among other things “Wayland is not supported”.
Answer
Anydesk is a client/server solution that uses an internal protocol. So it is explicitly not meant to be a remote X server or similar!
Anydesk is not part of the distribution, so the customer has to contact the support of Anydesk. There is no solution from Univention support here.
