Provider portal: sort of versions should list newer UCS versions at top
whenever you want to select an app version to edit it shows a list of possible versions. This lists the oldest UCS (in our case 4.1) at the top and the latest (4.3) at the bottom.
I think it would be nice if the order was changed to have newer releases at the top instead.
Hello @opsi4ucs
thank you very much for your feedback. I created https://forge.univention.org/bugzilla/show_bug.cgi?id=47936.
Best regards,
Nico
