Mais
Ferramentas
Português
Inglês
Hello. I’m trying to update UCS from version 5.0-10 errata1386 but without success. In any attempt to go to version 5.2 the system reports an error. I tried to do it since the UCS 5.2-0 version but the error is the same - “The update to UCS 5.1-0 failed. The log file /var/log/univention/updater.log may contain more information about this.” It seems that UCS itself tries to update to version 5.1 which is not recommended by UCS itself. Is there any way to perform the update correctly?
