Problems sending email
When I try to send email, the following error returns:
relay = smtp.gmail.com [64.233.186.108]: 587, delay = 0.74, delays = 0.1 / 0.02 / 0.43 / 0.19, dsn = 5.7.0, status = bounced (host smtp.gmail.com [64.233.186.108] said: 530 5.7.0 Must issue a STARTTLS command first. m103sm5763046qkh.20 - gsmtp (in reply to MAIL FROM command))
Do you know where I might be going wrong?
Best Regards,
Michael Voigt
The target host requires authentification (username/ password) through TLS.
So you have to check the postfix (?) configuration.
See here: https://blog.bartlweb.net/2011/02/smtp-relay-host-mit-authentifizierung-in-postfix-konfigurieren/
and
https://help.univention.com/t/eine-empfangerdomain-uber-relay-mit-auth/8320/12
Hey,
I found out here, the problem was tls_policy.db
I needed to run the postmap tls_policy
Now it works fine.
Best Regards,
Michael Voigt
