Problem: WLAN/ WiFi Access Through Radius Suddenly Not Working
WLAN/ WiFi access through radius suddenly not working.
Environment
Access was already configured and working fine. Out of the sudden clients can not connect to the WiFi any longer. Authentication is requested by your clients do not get an IP address.
Make sure your network is configured properly. You should not have switches connected as a loop. If so, make sure your switches have “Spanning Tree Protocol” activated.
