Problem with Univention Management Console
Hi, I’m having trouble on connecting to UCS console manager, its working on VMWare and it was supposed to work fine.
My log file says:
 15.08.18 14:49:00.969  MAIN        ( ERROR   ) : Traceback (most recent call last):
  File "/usr/sbin/univention-management-console-server", line 243, in <module>
    umc_daemon.do_action()
  File "/usr/lib/pymodules/python2.7/daemon/runner.py", line 186, in do_action
    func(self)
  File "/usr/lib/pymodules/python2.7/daemon/runner.py", line 131, in _start
    self.app.run()
  File "/usr/sbin/univention-management-console-server", line 199, in run
    from univention.management.console.protocol.server import Server
  File "/usr/lib/pymodules/python2.7/univention/management/console/protocol/__init__.py", line 187, in <module>
    from session import *
  File "/usr/lib/pymodules/python2.7/univention/management/console/protocol/session.py", line 56, in <module>
    from .client import Client, NoSocketError
  File "/usr/lib/pymodules/python2.7/univention/management/console/protocol/client.py", line 46, in <module>
    from OpenSSL import SSL
 File "/usr/lib/python2.7/dist-packages/OpenSSL/__init__.py", line 8, in <module>
    from OpenSSL import rand, crypto, SSL
  File "/usr/lib/python2.7/dist-packages/OpenSSL/rand.py", line 11, in <module>
    from OpenSSL._util import (
  File "/usr/lib/python2.7/dist-packages/OpenSSL/_util.py", line 4, in <module>
    binding = Binding()
  File "/usr/lib/python2.7/dist-packages/cryptography/hazmat/bindings/openssl/binding.py", line 89, in __init__
    self._ensure_ffi_initialized()
  File "/usr/lib/python2.7/dist-packages/cryptography/hazmat/bindings/openssl/binding.py", line 113, in _ensure_ffi_initialized
    libraries=libraries,
  File "/usr/lib/python2.7/dist-packages/cryptography/hazmat/bindings/utils.py", line 57, in build_ffi
    ffi.cdef("\n".join(cdef_sources))
  File "/usr/local/lib/python2.7/dist-packages/cffi/api.py", line 107, in cdef
    self._cdef(csource, override=override, packed=packed)
  File "/usr/local/lib/python2.7/dist-packages/cffi/api.py", line 121, in _cdef
self._parser.parse(csource, override=override, **options)
  File "/usr/local/lib/python2.7/dist-packages/cffi/cparser.py", line 315, in parse
    self._internal_parse(csource)
  File "/usr/local/lib/python2.7/dist-packages/cffi/cparser.py", line 320, in _internal_parse
    ast, macros, csource = self._parse(csource)
  File "/usr/local/lib/python2.7/dist-packages/cffi/cparser.py", line 278, in _parse
    self.convert_pycparser_error(e, csource)
  File "/usr/local/lib/python2.7/dist-packages/cffi/cparser.py", line 307, in convert_pycparser_error
    raise CDefError(msg)
CDefError: parse error
<cdef automatic initialization code>:1:13: before: FILE
did you solve the issue?
I have seen it several times but I currently do not have a solution in mind.
Did you try it the “Windows-Way” and rebooted the server? Upgraded it to the latest version? Still the issue?
/CV
