very strange problem here.
UCS / OX System (single node, just a master, no slaves)
- completely working 4.2-5 UCS shows following problems via “System diagnostic”:
Critical: Check validity of SSL certificates:
Found invalid certificate '/etc/univention/ssl/foo.bar.de/foo-bar.de.crt': /etc/univention/ssl/foo-bar.de/foo-bar.de.crt: OU = Domain Control Validated, CN = *.foo-bar.de error 20 at 0 depth lookup:unable to get local issuer certificate
I had not seen this issue before updating to 4.3 (but do see now after rolling back to this earlier snapshot), therefore triggered the update without worrying.
Update to 4.3-2 went incredibly smooth, no problems at all.
Univention / OX reachable afterwards, but mailsystem completely down.
Being a bit dumb this morning unfortunately i just rolled back the system to 4.2-5 without backing up the logfiles ![]()
but here’s what i still had in some terminal session, maybe it helps:
Sep 22 09:22:37 ucs slapd[1887]: <= mdb_equality_candidates: (userOptionsPreset) not indexed
Sep 22 09:22:38 ucs slapd[1887]: <= mdb_equality_candidates: (SAMLServiceProviderIdentifier) not indexed
Sep 22 09:23:02 ucs check_nrpe: Remote 45.5.123.123 accepted a Version 3 Packet
Sep 22 09:23:05 ucs dovecot: imap-login: Disconnected (auth failed, 1 attempts in 7 secs): user=karencorbett@foo-bar.de, method=PLAIN, rip=197.51.174.45, lip=45.5.123.123, TLS: Disconnected, session=
Sep 22 09:24:09 ucs dovecot: imap-login: Disconnected (auth failed, 1 attempts in 7 secs): user=roneggron@foo-bar.de, method=PLAIN, rip=61.153.54.38, lip=45.5.123.123, TLS, session=<30r1o3B2FL49mTYm>
Sep 22 09:24:23 ucs nagios: SERVICE ALERT: ucs.foo-bar.de;UNIVENTION_NTP;CRITICAL;SOFT;1;NTP CRITICAL: Offset unknown
Sep 22 09:24:38 ucs dovecot: imap-login: Disconnected (auth failed, 1 attempts in 8 secs): user=mirianaltamiranocalle@foo-bar.de, method=PLAIN, rip=222.76.48.121, lip=45.5.123.123, TLS: Disconnected, session=
Sep 22 09:24:43 ucs check_nrpe: Remote 45.5.123.123 accepted a Version 3 Packet
Sep 22 09:25:01 ucs CRON[3761]: (root) CMD ([ -x /usr/share/univention-ox/process-listener ] && /usr/share/univention-ox/process-listener)
Sep 22 09:25:01 ucs CRON[3763]: (root) CMD (if [ -x /usr/bin/mrtg ] && [ -r /etc/mrtg.cfg ] && [ -d “$(grep ‘[1][^#][[:space:]]*WorkDir’ /etc/mrtg.cfg | awk ‘{ print $NF }’)” ]; then mkdir -p /var/log/mrtg ; env LANG=C /usr/bin/mrtg /etc/mrtg.cfg 2>&1 | tee -a /var/log/mrtg/mrtg.log ; fi)
Sep 22 09:25:02 ucs check_nrpe: Remote 45.5.123.123 accepted a Version 3 Packet
Sep 22 09:25:11 ucs dovecot: imap-login: Disconnected (auth failed, 1 attempts in 5 secs): user=info@foo-bar.de, method=PLAIN, rip=123.12.123.12, lip=45.5.123.123, TLS, session=<Dwa8p3B2/O3aFrSS>
Maybe someone can tell me what went wrong here and how i would be able to solve this?
have yourself a great weekend and thanks a ton
Sascha
[:space:] ↩︎
