Problem with character size in username
Hello guys!
I approved the UCS for use here in the company. At most 100 users, but I found a problem with some of them.
Here we have already used samba 4 and we had no problems with the size of the login (username). When I migrated some of them, I found a barrier with a maximum size of 20 characters for the username. Is it possible to disable this or put some record in Univention so that you ignore this information?
Here all my systems and e-mail are connected to my samba 4 LDAP and will be migrated to UCS.
Thanks in advance
May you will find the answer in this bug-report dated in 2017:
https://forge.univention.org/bugzilla/show_bug.cgi?id=45577#c11
and
https://forge.univention.org/bugzilla/show_bug.cgi?id=47222
If Windows clients are used:
because the MS docs say that the samaccountname (aka “Pre Windows-2000 Logon Name”) “must be 20 characters or less to support earlier clients”. If this would be an RFC, nobody would say, “Ok, it says must, but I don’t have that use case”.
found here: 47222 – (usernamelengthlimit) Make it configurable to use usernames longer than 20 characters
81/5000
I can do it another way. using samba-tool. it accepts more than 20 characters.
“to support earlier clients”
yes… I don’t think that we should keep it that way if microsoft AD can do it since years now…
who has such old clients either way? and if someone rellay wants to use such a client… you can still use them with specific users for this.
that’s not even a feature request. That’s a straight up bug.
The username is represented in Samba / Windows AD as attribute samaccountname which has a fixed 20 character limit. This is not only for older clients, this is for compatibility with AD even today: SAM-Account-Name attribute - Win32 apps
Longer logins names in AD are the UPN (userprinciplename), not the samaccountname. We currently do not make the UPN visible in UCS as it is used only by some AD/Kerberos clients while the username / samaccountname can be used in any authentication method.
