I’ve used ad-takeover to get a DC migrated to UCS. The old DC was running on Ubuntu 20.04, which itself took over a 2008 R2.
I had the problem, that some users had no uidNumber, so they were not seen on getent passwd, and not discoverable by id. (both on UCS and the member server) I added them manually, so all was good.
But a day later, most (but not all) accounts disappeared again! This time only on the member server running proxmox, not on UCS itself) A debug session later I discovered that winbind said “could not find attribute uidNumber”. But it was still here - at least on the LDAP server and on UCS itself. I used the idmap “ad”, because I wanted to have the same uids as on UCS itself. The idmap rid let the users appear. The same happened on a newly created user.
Because I needed to get it running “somehow”, after a few hours of digging into it without getting a solution I took the big hammer. Or should I say “Big bottles from the poison cabinet and mixing it all together”?
Ingredients:
- UCS: php script + inetd
- member server: bash script + idmap script
php script:
sidtouid.php
#!/usr/bin/php
<?php
$input = readline();
$input = explode(' ', $input);
$inputarg = escapeshellarg(str_replace("\r","",str_replace("\n","",@$input[1])));
if ($input[0] == 'SIDTOID') {
// User?
$exec = 'wbinfo -S '.$inputarg.' 2>&1';
//echo "\n\n\n\n|$exec|\n\n\n\n";
$result = shell_exec($exec);
if (strpos($result,"failed")===false) {
echo "UID:$result";
die();
// Group?
$exec = 'wbinfo -Y '.$inputarg.' 2>&1';
echo "GID:$result";
die();
echo "ERR:1234\n";
die();
if ($input[0] == 'IDTOSID') {
$inputarg = str_replace("\r","",str_replace("\n","",$input[1]));
$inputarg2 = escapeshellarg(str_replace("\r","",str_replace("\n","",$input[2])));
if ($inputarg == 'XID') {
$exec = 'wbinfo -U '.$inputarg2.' 2>&1';
echo "SID:$result";
die();
echo "ERR:1235\n";
die();
if ($inputarg == 'UID') {
echo "SID:$result";
die();
echo "ERR:1236\n";
die();
if ($inputarg == 'GID') {
$exec = 'wbinfo -G '.$inputarg2.' 2>&1';
echo "SID:$result";
die();
echo "ERR:1237\n";
die();
echo "ERR:1240 |$inputarg|\n";
echo "ERR:1250\n";
inetd:
dict stream tcp nowait root /usr/sbin/tcpd /root/sidtouid.php
(needed to do a ucr set security/packetfilter/tcp/2628/all=ACCEPT)
bash script:
#!/bin/bash
input="$@";
echo `date` >> /tmp/sendsid.log
echo $input >>/tmp/sendsid.log
output=`echo $input | nc 192.168.10.250 dict`;
echo $output >>/tmp/sendsid.log
echo >> /tmp/sendsid.log
echo $output;
idmap script (samba config):
idmap config ADNAME:backend = script
idmap config ADNAME:range = 2000-9999
idmap config ADNAME:script = /root/sendsid.sh
The most worrisome thing: this smelly pile of crap actually works! (No, I refuse to call this a hack…)
But, is there a solution for this problem which can be called a “solution”?
