Wi-Fi printers fail to authenticate via FreeRADIUS after upgrade to UCS 5.2
After upgrading to UCS 5.2, Wi-Fi printers may fail to authenticate against FreeRADIUS using EAP-PEAP. The authentication fails during the TLS handshake due to stricter TLS handling or invalid printer certificates.
90) eap: Calling submodule eap_peap to process data
(90) eap_peap: (TLS) EAP Peer says that the final record size will be
170 bytes
(90) eap_peap: (TLS) EAP Got all data (170 bytes)
(90) eap_peap: (TLS) Handshake state - before SSL initialization
(90) eap_peap: (TLS) Handshake state - Server before SSL initialization
(90) eap_peap: (TLS) recv TLS 1.3 Handshake, ClientHello
(90) eap_peap: (TLS) send TLS 1.0 Alert, fatal protocol_version
(90) eap_peap: ERROR: (TLS) Alert write:fatal:protocol version
(90) eap_peap: ERROR: (TLS) Server : Error in error
(90) eap_peap: ERROR: (TLS) Failed reading from OpenSSL:
error:0A000102:SSL routines::unsupported protocol
(90) eap_peap: ERROR: (TLS) System call (I/O) error (-1)
(90) eap_peap: ERROR: (TLS) EAP Receive handshake failed during operation
(90) eap_peap: ERROR: [eaptls process] = fail
(90) eap: ERROR: Failed continuing EAP PEAP (25) session. EAP
sub-module failed
(90) eap: Sending EAP Failure (code 4) ID 2 length 4
(90) eap: Failed in EAP select
(90) [eap] = invalid
(90) } # authenticate = invalid
Symptoms:
Wi-Fi printers cannot connect to the WLAN
802.1X authentication fails
FreeRADIUS debug logs show TLS handshake errors, for example:
fatal protocol_versionunsupported protocolno suitable signature algorithm
Root Cause:
This issue can be caused by one or more of the following:
- Older printers only support deprecated TLS versions
- The TLS minimum version was not evaluated correctly in early UCS 5.2 releases - Bug 58374
- The certificate configured on the printer is expired or incompatible
The issue is resolved with:
- UCS 5.2 Erratum 292
Security and bugfix errata for Univention Corporate Server
With this erratum, the UCR variable below is evaluated correctly by FreeRADIUS:
freeradius/conf/tls-min-version
After installing the erratum, you could set the variable for example:
ucr set freeradius/conf/tls-min-version=1.0
Workaround (only if the erratum is not installed)
As a temporary workaround, the TLS minimum version can be enforced manually via the FreeRADIUS UCR template.
Edit the template:
/etc/univention/templates/files/etc/freeradius/3.0/mods-available/eap -
Add the following lines near the TLS configuration:
@!@ print('\t\ttls_max_version = %s' % configRegistry.get('freeradius/conf/tls-max-version', '1.3')) print('\t\ttls_min_version = %s' % configRegistry.get('freeradius/conf/tls-min-version', '1.0')) @!@ -
Apply the changes:
ucr commit /etc/freeradius/3.0/mods-available/eap -
Verify that the generated configuration contains:
tls_max_version = 1.3 tls_min_version = 1.0
Additional information
If authentication still fails after installing the erratum and configuring the TLS minimum version, check the certificate configured on the printer. Renewing or re-enrolling the printer certificate resolved the issue in confirmed cases.
Notes
- UCS 5.2 enforces stricter TLS defaults in FreeRADIUS
- Older or embedded devices may require explicit TLS minimum version configuration
- Printer certificates should be checked regularly for validity
