Problem: Where can I find the app settings
If the app is installed, then you go to the appcenter and check the corresponding app on the installed server. Then you will see the Install button, App Settings and uninstall button.
Bildschirmfoto%20vom%202019-08-16%2009-21-08
Then you can click the app settings button and you get a new configuration window
Bildschirmfoto%20vom%202019-08-16%2009-21-27
If the button with the app settings is grayed out, you may not be on the server where the app is installed.
