Users who are forced to change their password after a password reset are unable to successfully set a new password during login.
The issue occurs when a password reset is performed via the UMC with the option enabled that requires the user to change their password upon next login.
Steps to Reproduce
- Log in as a test teacher.
- Open the Passwords (Students) portal tile in the UMC.
- Reset a user’s password and enable the option “User must change password at next login”.
- Log in as the affected user.
- Enter the initial password and set a new password.
- The password change fails.
Analysis
It was observed that the password change is reliably accepted on the fourth attempt, which already indicated an underlying infrastructure issue rather than a frontend or policy problem.
Keycloak Logs
Relevant warnings were found in the Keycloak logs (univention-app logs keycloak), showing repeated UPDATE_PASSWORD_ERROR events with the error:
password_rejectedgensec_update failed - NT_STATUS_LOGON_FAILUREThe new password could not be set
This pointed towards an authentication or backend directory service issue.
Samba / Kerberos Logs
Further investigation in the Samba logs revealed Kerberos authentication failures with the status:
NT_STATUS_PROTOCOL_UNREACHABLE
This suggested that Kerberos requests were being sent to an endpoint that could not properly handle them.
Directory Replication (DRS)
A check using samba-tool drs showrepl revealed an unexpected replication connection:
- A school slave server (school01) was listed as a replication partner, even though it should not act as a replicating domain controller.
- The object had been created months earlier and could not be traced back reliably.
DNS and Kerberos SRV Records
On the backup servers running Keycloak, no Samba was installed. However, Kerberos was configured to discover KDCs via DNS SRV records.
DNS showed the following SRV entries:
_kerberos._tcp.schule.domain → master.schule.domain_kerberos._tcp.schule.domain → dc-backup02.schule.domain
The problem:
dc-backup02 runs Heimdal Kerberos (not Samba Kerberos), which cannot process the Samba-specific Kerberos requests required for password changes. As a result, some authentication attempts were routed to an incompatible KDC, causing intermittent failures.
1. Remove the Invalid Replication Partner
The school slave was removed from DRS using:
samba-tool domain demote --remove-other-dead-server school01
2. Clean Up Kerberos DNS SRV Records
Identify SRV records pointing to the backup DC:
udm dns/srv_record list --filter location=*dc-backup02.schule.domain*
The following entries were found and must be edited to remove dc-backup02:
_kerberos._tcp.schule.domain_kerberos._udp.schule.domain
This can be done either via command line or directly in the UMC.
3. Verify DNS Resolution
On a backup server, verify that Kerberos SRV records now only point to valid Samba DCs:
host -t SRV _kerberos._tcp.schule.domain
4. Repeat Cleanup for the School Slave
Check for DNS entries referencing the former school slave:
udm dns/srv_record list --filter location=*school01*
Any SRV records listing both the master and school01 should be reviewed and corrected accordingly.
