Problem: Users could not be activated for O365
The logfile `/var/log/univention/listener.log shows this error messages:
  File "/usr/lib/python3/dist-packages/univention/listener/api_adapter.py", line 165, in _handler
    self._module_handler.modify(dn, old, new, self._saved_old_dn if self._rename else None)
  File "/usr/lib/univention-directory-listener/system/office365-user.py", line 76, in modify
    self.connector.modify(new_udm_user=new_udm_user, old_udm_user=old_udm_user)
  File "/usr/lib/python3/dist-packages/univention/office365/connector/connector.py", line 582, in modify
    self.new_or_reactivate_user(new_udm_user, core)
  File "/usr/lib/python3/dist-packages/univention/office365/connector/connector.py", line 482, in new_or_reactivate_user
    user_azure.create_or_modify()
  File "/usr/lib/python3/dist-packages/univention/office365/microsoft/objects/azureobjects.py", line 375, in create_or_modify
    response = self._core.add_user(self.get_not_none_values_as_dict())
  File "/usr/lib/python3/dist-packages/univention/office365/microsoft/core.py", line 607, in add_user
    expected_status=[201]
  File "/usr/lib/python3/dist-packages/univention/office365/microsoft/core.py", line 853, in _call_graph_api
    raise typecast_error_into_child_class(error)
univention.office365.microsoft.exceptions.core_exceptions.MSGraphError: HTTP response status: 400
HTTP response expected status: [201]
> request url: https://graph.microsoft.com/v1.0/users
> request header: {
  "User-Agent": "Univention Microsoft 365 Connector",
  "Accept-Encoding": "gzip, deflate",
  "Accept": "*/*",
  "Connection": "keep-alive",
  "Content-Type": "application/json",
  "Authorization": "XXX",
  "Content-Length": "418"
> request body: {
  "displayName": "Christina Scheinig",
  "mailNickname": "cscheini",
  "accountEnabled": true,
  "givenName": "Christina Scheinig",
  "onPremisesImmutableId": "MTRlYzIxNDYtNDFkMC0xMDNmLTlhYWItZDliN2YxNTA5NGIz",
  "otherMails": [
    "cscheini@superpb.me"
  "surname": "Scheinig",
  "usageLocation": "DE",
  "userPrincipalName": "cscheini@sun.superbp.me"
> response header: {
> response body: {
  "error": {
    "code": "Request_BadRequest",
    "message": "The domain portion of the userPrincipalName property is invalid. You must use one of the verified domain names in your organization.",
    "details": [
        "code": "InvalidValue",
        "target": "userPrincipalName"
Investigation:
This is a mean typo here. Difficult to find, but the error message helps to check
  1. the registered domains in azure (Name of the user-defined domains)
  2. the logfile /var/log/univention/listener.log and/or /var/log/univention/listener_modules/office365-user.log
    3 /usr/share/univention-office365/scripts/manage_adconnections list to get the path to the connections → /etc/univention-offce365/>connection-alias>
Check where the typo occured.
In this case we found the cause in
/etc/univention-office365/sun/ids.json
{"adconnection_alias": "sun", "client_id": "XXXXXXXX-xxxx-xxxx-XXXX-XxXxXxXxXxXx", "adconnection_id": "xxxxxxxx-XXXX-XXXX-xxxx-xXxxXxXxxXXx", "reply_url": "https://10.200.43.45/microsoft365-authorize", "domain": "sun.superbp.me"}
So changeing this with an editor to the right domain part, the users will now be synchronized. You may have to retrigger the user by changing the description.
