Users can not login any more to any service or through Windows clients.
Additionally you can not join any server to your UCS domain and you will see following screen:
Investigation
Check replication status:
root@ucs01:~# univention-directory-listener-ctrl status
Listener status:
finish: univention-directory-listener: (pid 7920) 6s, normally down
Current Notifier ID on "ucs.multi.intranet"
2525
Last Notifier ID processed by local Listener:
2212
Last transaction processed:
2525 cn=app_syntax,cn=udm_syntax,cn=univention,dc=multi,dc=intranet a
Modules:
3 bind /usr/lib/univention-directory-listener/system/bind.py
3 dhcp /usr/lib/univention-directory-listener/system/dhcp.py
You notice the difference between “Current Notifier ID” and “Last Notifier ID…”. This can be caused by different reasons.
This time a check of disk usage showed the /- filesystem being out of space:
root@ucs:~# df -h
Dateisystem Größe Benutzt Verf. Verw% Eingehängt auf
udev 10M 0 10M 0% /dev
tmpfs 792M 13M 779M 2% /run
/dev/dm-0 15G 15G 0G 100% /
/dev/sda1 472M 149M 300M 34% /boot
Further investigation about the used disk space there was a huge amount of space used under the /var. Expected sizes are around 10GB but this may vary.
root@ucs:~# du -hs /var /usr/
12G /var
1,5G /usr/
By narrowing down with the “du” command the directory /var/lib/univention-connector/ad used about 11G of disk space. Inside of this directory existed millions of very small “pickle files” used to synchronize between a UCS domain and the AD through univention-ad-connector which was installed.
But in this environment no Microsoft AD existed thus the AD-Connector was installed but not configured nor active. Therefore the files for synchronization did never get cleaned up.
Step 1
Remove most of the files. As long as the AD-connector is installed there will be new files created. For the moment this is not important. Just free some space by the following command which will take a while:
rm /var/lib/univention-connector/ad/*
Note: Second option is to increase disk space by adding additional harddisks and extending the /-filesystem.
Step 2
Use Univention Management Console (UMC) to remove the AD-connector app.
On command line you could remove the app as follows: univention-app remove adconnector
Step 3
Restart replication services:
systemctl restart univention-directory-notifier
systemctl restart slapd
systemctl restart univention-directory-listener
