After updating from 4.2 to 4.3, users on Debian systems could no longer log in successfully. Login was ok, but the desktop did not appear immediately. It took at least 5 minutes until the users finally had their desktop.
Environment
User home directories were mounted to the Debian clients via NFS (as /home/users/USERNAME).
In the logs of both the server and the Debian client, there were indications that the NFS-lockd was not available. NFS-lockd is superfluous with NFSv4.
The clients had mounted the shares in /etc/fstab with “v3”.
Option 1
Change version option in the client’s /etc/fstab from “v3” to “v4”.
Option 2
Verify the rpc service is enabled and running on the UCS server as this service is needed for NFS locking.
root@ucs:/var/log# systemctl enable rpc-statd
Created symlink /etc/systemd/system/nfs-server.service.wants/rpc-statd.service → /lib/systemd/system/rpc-statd.service.
root@ucs:/var/log# systemctl start rpc-statd
root@ucs:/var/log# systemctl status rpc-statd
● rpc-statd.service - NFS status monitor for NFSv2/3 locking.
Loaded: loaded (/lib/systemd/system/rpc-statd.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2019-04-11 11:06:00 CEST; 2s ago
Process: 24809 ExecStart=/sbin/rpc.statd --no-notify $STATDARGS (code=exited, status=0/SUCCESS)
Main PID: 24810 (rpc.statd)
