Problem: Upgrade Fails With An Error Related To PostgreSQL
You attempted to perform an upgrade which fails. In /var/log/univention/updater.log you will notice the following errors:
Errors were encountered while processing:
postgresql-common
postgresql-9.1
postgresql-server-dev-9.1
Trying to fix the package database results the following error:
root@ucs:~# dpkg --configure -a
postgresql-common (165+deb8u2A~4.2.0.201703021601) wird eingerichtet ...
[....] Starting PostgreSQL 9.1 database server: main[....] The PostgreSQL server failed to start. Please check the log output: 2019-05-10 17:12:39 CEST
LOG: could not open configuration file "/etc/p[FAILesql/9.1/main/pg_hba.conf":
No such file or directory 2019-05-10 17:12:39 CEST FATAL: could not load pg_hba.conf ... failed!
failed!
dpkg: Fehler beim Bearbeiten des Paketes postgresql-server-dev-9.1 (--configure):
Abhängigkeitsprobleme - verbleibt unkonfiguriert
postgresql-common
postgresql-9.1
Investigation
This might be a left-over from an earlier app which has been removed a while ago.
Make sure there are no databases configured in PostgreSQL:
root@ucs:~# ls -alh /etc/postgresql
insgesamt 20K
drwxr-xr-x 3 root root 4,0K Mai 4 14:30 .
drwxr-xr-x 169 root root 12K Mai 13 11:08 ..
drwxr-xr-x 3 postgres postgres 4,0K Mär 2 2016 9.1
Check the content in the directory /etc/postgresql/9.1 if it is currently in use (ie by checking the file last access dates). In case you are sure no app is using a PostgreSQL database you can remove the packages:
apt remove postgresql-common
apt remove postgresql-9.1
apt remove postgresql-server-dev-9.1
The restart the upgrade from console:
univention-upgrade --ignoreterm --ignoressh --updateto=4.2-0
