Problem: univention-s4connector-list-rejected shows a traceback
You are getting a traceback and an error message when starting univention-s4connector-list-rejected:
root@backup:~# univention-s4connector-list-rejected
  File "/usr/sbin/univention-s4connector-list-rejected", line 73, in <module>
    import mapping
ImportError: No module named mapping
Environment
Rejects can only listed on the UCS server where the s4connector is active. You could verify if it is active on your current server:
root@master:~# systemctl status univention-s4-connector
● univention-s4-connector.service - LSB: Univention S4 Connector
   Loaded: loaded (/etc/init.d/univention-s4-connector; generated; vendor preset: enabled)
   Active: active (running) since Tue 2019-01-29 13:05:39 CET; 4h 35min ago
In case it is not running you will get the following output:
root@backup:~# systemctl status univention-s4-connector
   Loaded: masked (/dev/null; bad)
   Active: inactive (dead)
Note: The S4-connector should only be active on one server within the domain! Do not attempt to start it while it is running on an other server!
Execute the failing command on a server where the S4-connector is running (see above).
