When executing the command univention-pkgdb-scan you get the following Traceback:
root@ucsdc0:/home/univention-support#
File "/usr/sbin/univention-pkgdb-scan", line 41, in <module>
univention.pkgdb.main()
File "/usr/lib/python3/dist-packages/univention/pkgdb.py", line 589, in main
connection = open_database_connection(config_registry, pkgdbu=False)
File "/usr/lib/python3/dist-packages/univention/pkgdb.py", line 571, in open_database_connection
connection = pgdb.connect(database=connectstring)
File "/usr/lib/python3/dist-packages/pgdb.py", line 1619, in connect
cnx = _connect(dbname, dbhost, dbport, dbopt, dbuser, dbpasswd)
pg.InternalError: FATAL: Password authentication for user »ucsdc0$« failed
Hint
In this scenario it is important to mention that the package for univention-pkdg, i.e. the pkgdb server itself, is not located on the primary node / DC master (ucsdc0).
This plays an important role later in the solution, because the host name and domain name must match the pkgdb server so that the pkgdb can also be accessed.
Environment
root@ucs-pkgdb:/home/univention-support# univention-app info
UCS: 5.0-8 errataXXX
Installed: pkgdb=11.0
root@ucs-pkgdb:/home/univention-support# dpkg -l | grep pkgdb
ii python3-univention-pkgdb 13.0.5-2 all UCS - Software monitoring database Python 3 library
ii univention-management-console-module-pkgdb 13.0.5-2 all UMC module for software monitoring database
ii univention-pkgdb 13.0.5-2 all UCS - Software monitoring database
ii univention-pkgdb-tools 13.0.5-2 all UCS - Software monitoring database tools
root@ucsdc0:/home/univention-support# dpkg -l | grep pkgdb
You have to add the User to the DATABASE pkgdb on the system, where univention-pkgdb is installed so, which system is your pkgdb Server.
univention-pkgdb-scan --db-server "$(hostname -f)" --add "ucsdc0$"
SQL: CREATE USER "ucsdc0$" IN GROUP pkgdbg
SQL: ALTER GROUP pkgdbg ADD USER "ucsdc0$"
Hint
This comes from the join script you will find under/usr/lib/univention-install/50univention-pkgdb.inst
univention-pkgdb-scan --db-server "$hostname.$domainname" --add "$hostname$"
Fixed output:
Reading package lists... Done
Building dependency tree
Reading state information... Done
For missing hosts in the pg_hba.conf, check the following article.
To recreate the DATABASE pkgdb, check the following article.
PostgreSQL Cheat Sheet
