Problem: univention-keycloak certificate verify failed
The Keycloak join-log as well as univention-keycloak commands are serving errors like:
CREATING KEYCLOAK SAML CLIENT.....
  File "/usr/lib/python3/dist-packages/urllib3/contrib/pyopenssl.py", line 453, in wrap_socket
    cnx.do_handshake()
  File "/usr/lib/python3/dist-packages/OpenSSL/SSL.py", line 1915, in do_handshake
    self._raise_ssl_error(self._ssl, result)
  File "/usr/lib/python3/dist-packages/OpenSSL/SSL.py", line 1647, in _raise_ssl_error
    _raise_current_error()
  File "/usr/lib/python3/dist-packages/OpenSSL/_util.py", line 54, in exception_from_error_queue
    raise exception_type(errors)
OpenSSL.SSL.Error: [('SSL routines', 'tls_process_server_certificate', 'certificate verify failed')]
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='sso.univention.intranet', port=443): Max retries exceeded with url: /realms/master/protocol/openid-connect/token (Caused by SSLError(SSLError("bad handshake: Error([('SSL routines', 'tls_process_server_certificate', 'certificate verify failed')])")))
Nevertheless, checking the corresponding certificate by curl did not return any error compared to python:
root@ucs-backup:~# curl https://sso.univention.intranet
root@ucs-backup:~# python3 -c 'import requests; requests.get("https://sso.univention.intranet")'
    cnx.do_handshake()
Update the internal certificate store:
update-ca-certificates
