Situation:
With UCS 5.2 the UMC diagnostic module complains about deprecated Samba database type TDB.
This is due to the fact that with UCS 5.2 the default for the Samba database changed from TDB to LMDB. During the update to UCS 5.2 the Samba database is not automatically migrated. So if you still have TDB as database for Samba you need to migrate to LMDB.
Migration to LMDB Samba database:
Arrange a maintenance window for the conversion of the Samba SAM database backend from TDB to LMDB. While TDB has a hard limit of 4GB, the LMBD database format can be adjusted to accommodate larger amounts of data. The LMDB database technology is also used by OpenLDAP, so we consider it to be fit for the job.
For the migration you can use the python script /usr/share/univention-samba4/scripts/migrate-samldb-from-tdb-to-mdb.py (as of UCS 5.2 part of the Samba integration package).
The script will run a samba-tool dbcheck --cross-ncs before and after the migration, which will take the largest time. In case you want to reduce the downtime you could consider performing the dbcheck separately before the migration and start the script with the option migrate-samldb-from-tdb-to-mdb --skip-dbcheck. This is considered to be safe, because the migration treats all the data as opaque blobs. The dbcheck issues would be on a higher level than where the script operates. Please note that the script needs to be run on all UCS Samba/AD DCs individually, as it’s really just about the local backend storage technology.
Since UCS 5.0-5 Errata 811 two new UCR variables samba/database/backend/store and samba/database/backend/store/size have been added to configure the samba database backend (tdb or mdb) before the initial setup, join or re-join. When starting to migrate from tdb to mdb it is recommended to aim for a consistent configuration of these variables on all UCS Samba/AD domain controllers. E.g. choosing mdb for the UCS Primary Directory Node but staying with tdb on a replicating node will cause trouble when the data size in one of the Samba/AD SAM backend stores (i.e. naming contexts) grows beyond the limits possible with tdb. The errata update was released explicitly to help customers to avoid that, e.g. by setting these UCR variables uniformly with a UDM policy.
The size limit given in samba/database/backend/store/size (default 8GB) is effecting the individual backend store files in /var/lib/samba/private/sam.ldb.d/*.ldb. Since there are typically 5 naming contexts (domain, configuration, schema, DomainDNSZones and ForestDNSZones), care should be taken that the storage has enough room for the total size. The size limit given in samba/database/backend/store/size can be raised at any time by adjusting the UCR variable and then restarting samba. It must never be decreased though (that’s how LMDB works).
To summarize a plan for migration of a UCS domain could look like this:
- set
samba/database/backend/store=mdbvia UCR on all UCS Directory Nodes that run Samba/AD services (e.g. via UDM policy) - Pick one UCS Backup and Replica Directory Node that runs Samba/AD as the first candidate for migration. Depending on the amount of data, a service window should be scheduled for that. Use
/usr/share/univention-samba4/scripts/migrate-samldb-from-tdb-to-mdb.pyto migrate the samba database. - Verify that the system runs normally.
- Continue with other DCs one by one.
- Finally, on the Primary use
/usr/share/univention-samba4/scripts/migrate-samldb-from-tdb-to-mdb.pyto migrate it to LMDB.
