In UMC the diagnostic module reports an error:
samba-tool ntacl sysvolcheck meldet ein Problem mit den SYSVOL ACL Einträgen. STDOUT: get_nt_acl_conn: get_nt_acl returned NT_STATUS_OBJECT_NAME_NOT_FOUND. (2, 'No such file or directory') (-1073741772, 'The object name is not found.')
Environment
UCS 4.x domain with several UCS host types (master, backup, slave) and GroupPolicyObjects (GPO) being used.
Remove the referenced GPO which will remove it from SYSVOL, too. Re-create the object then correctly.
Investigation
Step 1
Start sysvolreset and check output
root@slave1:~# samba-tool ntacl sysvolreset
set_nt_acl_conn: open: error=2 (No such file or directory)
Unable to set ACL O:DAG:DAD:PAR(A;OICI;0x001f01ff;;;DA)(A;OICI;0x001f01ff;;;EA)(A;OICIIO;0x001f01ff;;;CO)(A;OICI;0x001f01ff;;;DA)(A;OICI;0x001f01ff;;;SY)(A;OICI;0x001200a9;;;AU)(A;OICI;0x001200a9;;;ED) on /var/lib/samba/sysvol/domain.com/Policies/{E4DD7CDA-3AA2-4A79-B9E5-8F550F841657}
The part DAG:DAD:PAR tells about the path where the ACL should be applied. Here, the policy ID is {E4DD7CDA-3AA2-4A79-B9E5-8F550F841657} to identify the GPO in GPO-editor.
Step 2
In GPO editor check the referenced GPO and remove it needed. It might be settled at a wrong place.
