usschool userimport shows the following traceback:
Interner Server-Fehler in "schoolimport/ping".
Request: schoolimport/ping
File "%PY2.7%/univention/management/console/protocol/modserver.py", line 186, in _recv
self.handle(msg)
File "%PY2.7%/univention/management/console/protocol/modserver.py", line 296, in handle
self.__handler.init()
File "%PY2.7%/univention/management/console/modules/schoolimport/__init__.py", line 62, in init
self.client = Client(self.username, self.password, log_level=Client.LOG_RESPONSE)
File "%PY2.7%/ucsschool/http_api/client.py", line 382, in __init__
setattr(self, cls_name, kls(self))
File "%PY2.7%/ucsschool/http_api/client.py", line 480, in __init__
self.resource_url = self.client.resource_urls[self.resource_name]
File "%PY2.7%/ucsschool/http_api/client.py", line 392, in resource_urls
self._resource_urls = self.call_api('get', '.')
File "%PY2.7%/ucsschool/http_api/client.py", line 457, in call_api
raise ConnectionError(str(exc))
ConnectionError: hostname '***' doesn't match either of '***', '***'
This problem could occure if you are using lets encrypt certificates.
If external SSL certificates (from e.g. let’s encrypt) are used on the domaincontroller master and master’s FQDN differs from the FQDNs within the SSL certificate, the UMC module “Benutzerimport” threw a traceback. The new UCR variables ucsschool/import/http_api/client/server and ucsschool/import/http_api/client/ssl_verify now allow to specify the correct FQDN used in the SSL certificates resp. to disable SSL checks at all (the latter one is NOT recommended!) (Bug 47911).
ucr set ucsschool/import/http_api/client/server=**
(and than “service univention-management-console-server restart”).
→ logout and login again → new UMC module process
or
ucr set ucsschool/import/http_api/client/ssl_verify=false
