If you have connection issues with the ucsschool-veyon-proxy and the
/var/log/univention/management-console-module-computerroom.log
shows this error messages
MODULE ( ERROR ) : Fetching feature status failed: Limit for maximum number of connections reached
You have to check the app settings for “UCS@school Veyon Proxy” in the appcenter for
Maximum number of connections for the veyon WebAPI
with the following command you check the UCR variable via terminal
ucr search veyon/WebAPI/ConnectionLimit
veyon/WebAPI/ConnectionLimit: 5000
and with an ucr set you can change the value
ucr set veyon/WebAPI/ConnectionLimit=5000
Sometimes the entered value in the Docker container is not set correctly as in the settings or the UCRV, so use the following command to check the config from the Docker container
univention-app shell ucsschool-veyon-proxy /usr/bin/veyon-cli config list | grep WebAPI/ConnectionLimit
With the next command you can check the configuration from the appcenter
univention-app configure --list ucsschool-veyon-proxy | grep veyon/WebAPI/ConnectionLimit
veyon/WebAPI/ConnectionLimit: 5000 (Maximum number of connections for the veyon WebAPI)
To change the configuration for the appcenter and the Docker container use
univention-app configure ucsschool-veyon-proxy --set veyon/WebAPI/ConnectionLimit=5000
