UCS Upgrade blocked due to Opsi Application Component
When attempting to upgrade a UCS 5.0-10 system to the next minor release (e.g., UCS 5.2), the upgrade may be blocked if the Opsi application is installed. The system may report that the upgrade is not available due to a required component being marked as incompatible or missing meta information.
Environment
UCS Version: 5.0-10 errata1300
Installed Applications:
- opsi=4.3.0.50-ucs5
- Additional apps: cups, dhcp-server, radius, samba4, squid, ucsschool, ucsschool-veyon-proxy
Upgrade Path: UCS 5.0-10 → UCS 5.1 → UCS 5.2
Error Triggered During:
univention-upgrade --ignoressh --ignoreterm --check
Issue Description
When checking for available UCS release upgrades, the system returns:
Checking for release updates: The update to UCS 5.1-0 is blocked because the component 'opsi_20250604391845' is marked as required.
No update available.
This indicates that the installed Opsi component is blocking the upgrade due to missing or outdated meta information for the next UCS version.
The pre-update check for UCS 5.2 passes without any issues, confirming that the system itself is otherwise prepared for the upgrade.
Root Cause
The upgrade was blocked due to:
Missing meta information for the Opsi app for UCS 5.1 in the Univention App Center.
Opsi version 4.3.0.50-ucs5 does not provide compatibility data required for UCS 5.1.
As a result, Univention’s upgrade process halts to prevent system inconsistency or potential incompatibility.
Opsi has updated the app and fixed the issue.
Note: The required versions:
5.0-x → 4.3.0.51-ucs5
5.1 → 4.3.0.51-ucs51
5.2-x → 4.3.0.51-ucs52
To resolve the issue and proceed with the UCS upgrade:
Step 1: Update the App Center Metadata
Ensure the system has the latest metadata from the App Center:
univention-app update
Step 2: Upgrade the Opsi Application
Upgrade the Opsi app to the latest available version compatible with UCS 5.1:
univention-app upgrade opsi
Step 3: Upgrade UCS to the next Version
Once the Opsi app has been successfully upgraded, proceed with the UCS system upgrade:
