UCS@school Veyon Proxy Reinstallation Error: “docker is to be ignored”
When attempting to reinstall the ucsschool-veyon-proxy app, specifically with univention-app install ucsschool-veyon-proxy=4.9.1.12-ucs1, the following error occurs:
Cannot use [App(id="ucsschool-veyon-proxy", version="4.9.1.12-ucs1", ucs_version="5.0", server="https://appcenter.software-univention.de")] as docker is to be ignored, yet, only non-docker versions could be found
This error indicates that the system is configured to ignore Docker-based app installations for ucsschool-veyon-proxy, but the available versions are only non-Docker. This creates a conflict preventing the installation.
The error arises because a UCR (Univention Configuration Registry) variable is set to ignore Docker for the ucsschool-veyon-proxy app. To resolve this, you need to unset this variable, allowing the App Center to properly identify and install the available non-Docker version.
Follow these steps on your UCS master or relevant DC-Slave:
Check the UCR variable:
First, verify if theappcenter/prudence/docker/ucsschool-veyon-proxyvariable is set toyes.root@dc-slave:~ # ucr info appcenter/prudence/docker/ucsschool-veyon-proxy appcenter/prudence/docker/ucsschool-veyon-proxy: yes -
Unset the UCR variable:
If the variable is set toyes, unset it using theucr unsetcommand.root@dc-slave:~ # ucr unset appcenter/prudence/docker/ucsschool-veyon-proxy Unsetting appcenter/prudence/docker/ucsschool-veyon-proxyThis command removes the specific configuration that tells the App Center to ignore Docker for this particular app.
List available versions (optional but recommended):
After unsetting the UCR variable, you can re-list the availableucsschool-veyon-proxyversions to confirm that the App Center can now correctly identify them.root@dc-slave:~ # univention-app list ucsschool-veyon-proxy ucsschool-veyon-proxy Name: UCS@school Veyon Proxy Versions: 4.8.3.8 4.8.3.8-ucs1 4.9.0.8-ucs1 4.9.1.12-ucs1 Installed: test1.uni.schule test2.uni.schule test3.uni.schule test4.uni.schule test5.uni.schule test6.uni.schule test7.uni.schule test8.uni.schule test9.uni.schuleYou should see the list of available versions, including
4.9.1.12-ucs1. -
Reinstall the app:
Now, you can proceed with the reinstallation ofucsschool-veyon-proxy. You no longer need to specify the exact version if you want the latest available one, asunivention-app install ucsschool-veyon-proxywill automatically select it.root@dc-slave:~ # univention-app install ucsschool-veyon-proxy Resolving dependencies for ucsschool-veyon-proxy Going to install UCS@school Veyon Proxy (4.9.1.12-ucs1) Password for Administrator:The installation should now proceed without the “docker is to be ignored” error.
