If the service cannot be started by the ID connector, it may be due to unprocessed pid file blocking the service. Among other things, this can be caused by a power failure in the system.
The Bug 54640 causes this misbehavior.
You will get this output if you check the container log with:
univention-app logs ucsschool-id-connector
This init-script assumes that old pid-files are removed and fails to start once a remnant exists. This may be tha case on unclean shutdown.
/etc/init.d # ./ucsschool-id-connector start
* Starting UCS@school ID Connector ...
File "/ucsschool-id-connector/src/queue_management", line 170, in <module>
_start()
File "/ucsschool-id-connector/src/queue_management", line 151, in _start
service.start()
File "/usr/lib/python3.8/site-packages/service/__init__.py", line 461, in start
raise ValueError('Daemon is already running at PID %d.' % pid)
ValueError: Daemon is already running at PID 146. [ !! ]
* ERROR: ucsschool-id-connector failed to start
/etc/init.d # cat /tmp/IDConnectorService.pid
146
/etc/init.d #
/etc/init.d # pgrep IDConnectorService
/etc/init.d # rm /tmp/IDConnectorService.pid
Started IDConnectorService daemon. [ ok ]
/etc/init.d # ./ucsschool-id-connector status
* status: started
Connect into the container and check if an old PID File exist.
univention-app shell ucsschool-id-connector
/ucsschool-id-connector # ls -lah /tmp/
drwxrwxrwx 1 root root 4.0K Dec 10 16:36 .
drwxr-xr-x 1 root root 4.0K Dec 9 14:14 ..
-rw-r--r-- 1 root root 4 Dec 10 16:36 IDConnectorService.pid
So there is an old PID File exist, go further with reset the state in the container.
/etc/init.d/ucsschool-id-connector stop/etc/init.d/ucsschool-id-connector zap/etc/init.d/ucsschool-id-connector start
Connect out of the container with cntr+d and check again the container logs, to see that the ID-Connector works again and the error is fixed.
