Problem: UCS@school - ID Broker Plugin - ModuleNotFoundError: lazy_object_proxy
UCS@school - ID Broker Plugin ModuleNotFoundError: lazy_object_proxy
A school authority installation was performed according to the documentation:
https://docs.software-univention.de/idbroker-school-authority-manual/installation.html
The installation itself and the first test step (API access) work correctly.
During the configuration step, adding the school_authority succeeds without any errors.
However, when running initial_sync.py, the process fails and does not continue.
Command used:
univention-app shell ucsschool-id-connector \
/var/lib/univention-appcenter/apps/ucsschool-id-connector/conf/plugins/packages/idbroker/initial_sync.py --dry-mode
Error message:
  File "/var/lib/univention-appcenter/apps/ucsschool-id-connector/conf/plugins/packages/idbroker/initial_sync.py", line 42, in <module>
    import lazy_object_proxy
ModuleNotFoundError: No module named 'lazy_object_proxy'
Environment
UCS: 5.0-10 errata1344
Installed: prometheus-node-exporter=2.0.1 radius=5.0 samba4=4.16
ucsschool=5.0 v4 ucsschool-id-connector=3.0.4
4.4/openid-connect-provider=2.2-konnect-0.33.11-2
The ID Broker Plugin installed:
id-broker-id-connector-plugin 1.3.18
Investigation
Inside the ID connector container, the module lazy-object-proxy was expected to be present.
Verification command:
pip install lazy-object-proxy
On a reference system, the module is already installed:
Requirement already satisfied: lazy-object-proxy in /venv/lib/python3.11/site-packages (1.10.0)
However, the script header in:
contains:
#!/usr/bin/python3
But inside the container, python3 resolves to:
/venv/bin/python3
Therefore, the script is executed using the wrong Python interpreter, which does not have the required modules installed.
Additionally, all related scripts originate from the Univention ID Broker Plugin, currently installed in an outdated version.
Verification of script ownership:
dpkg -S create_idbroker_client.py
id-broker-id-connector-plugin: /var/lib/univention-appcenter/apps/ucsschool-id-connector/conf/plugins/packages/idbroker/create_idbroker_client.py
Version check:
apt-cache policy id-broker-id-connector-plugin
This revealed that the system was using an old version of the plugin because the ucsschool app itself was outdated.
The package id-broker-id-connector-plugin depends on ucsschool.
Since ucsschool was outdated, the plugin also remained in an older version.
Updating ucsschool updates the plugin automatically.
Steps to fix the issue
univention-app update
univention-app upgrade ucsschool
After upgrading, the correct plugin version was installed and the scripts executed successfully with the correct Python environment.
Resolution
After the update, the correct version is shown:
  Installed:           2.2.4
  Candidate:           2.2.4
  Version table:
 *** 2.2.4 500
        500 https://appcenter.software-univention.de/univention-repository/5.2/maintained/component ucsschool_20250902122950/all/ Packages
        100 /var/lib/dpkg/status
     2.2.3 500
     2.2.2 500
     1.6.14 500
     1.6.5 500
After updating UCS School, the ID Broker connector plugin was upgraded to the correct version and the initial_sync.py script worked without errors.
