While in exam mode, you will receive the following traceback in the UMC and cannot collect exam results from students.
Interner Server-Fehler in "schoolexam/exam/collect".
Request: schoolexam/exam/collect
File "/usr/lib/python3/dist-packages/univention/management/console/base.py", line 388, in __error_handling
six.reraise(etype, exc, etraceback)
File "/usr/lib/python3/dist-packages/six.py", line 693, in reraise
raise value
File "/usr/lib/python3/dist-packages/univention/management/console/base.py", line 285, in execute
function.__func__(self, request, *args, **kwargs)
File "/usr/lib/python3/dist-packages/univention/management/console/modules/decorators.py", line 189, in _response
return function(self, request)
File "/usr/lib/python3/dist-packages/univention/management/console/modules/decorators.py", line 478, in _response
result = _multi_response(self, request)
File "/usr/lib/python3/dist-packages/univention/management/console/modules/decorators.py", line 602, in _response
return list(function(self, iterator, *nones))
File "/usr/lib/python3/dist-packages/univention/management/console/modules/decorators.py", line 444, in _fake_func
yield function(self, *args)
File "/usr/lib/python3/dist-packages/univention/management/console/modules/schoolexam/__init__.py", line 827, in collect_exam
project.collect()
File "/usr/lib/python3/dist-packages/univention/management/console/modules/distribution/util.py", line 756, in collect
available_space = self._get_available_space()
File "/usr/lib/python3/dist-packages/univention/management/console/modules/distribution/util.py", line 689, in _get_available_space
statvfs = os.statvfs(self.sender_projectdir)
FileNotFoundError: [Errno 2] Datei oder Verzeichnis nicht gefunden: '/home/mejneschool2/lehrer/m.muster/Klassenarbeiten/Univention-Test-Ergebnisse'
Environment
UCS: 5.0-9 errata1145
Installed: cups=2.2.1 dhcp-server=12.0 samba4=4.16 self-service=5.0 squid=3.5 ucsschool=5.0 v6 ucsschool-veyon-proxy=4.9.0.8-ucs1
Upgradable:
You have to remove the immutable flag from the directory where the exam results are stored.
1st. Check if a immutable_flag is set.
lsattr -d /home/mejneschool2/lehrer/m.muster/Klassenarbeiten/
Example:
----i-----e--- /home/mejneschool2/lehrer/m.muster/Klassenarbeiten/
2nd. Remove the immutable_flag
chattr -i /home/mejneschool2/lehrer/m.muster/Klassenarbeiten/
Example:
----------e--- /home/mejneschool2/lehrer/m.muster/Klassenarbeiten/
If several teachers are involved at the school, you can also use the following script. This will then remove the immutable flag under /home/$(hostname)/teacher/.
For UCS@school-Server
remove_immutable_flag.sh (331 Bytes)
#!/bin/bash
# Verzeichnis definieren
DIR="/home/$(hostname)/lehrer/"
# Schleife, um durch alle Dateien und Verzeichnisse zu gehen
find "$DIR" -type f -or -type d | while read -r file; do
# Entferne das immutable Flag
chattr -i "$file"
done
echo "Das immutable-Flag wurde für alle Dateien und Verzeichnisse entfernt."
Command to use as root:
chmod +x remove_immutable_flag.sh -
. remove_immutable_flag.sh
For paedML-Single-School-Server
clean.sh (317 Bytes)
#!/bin/bash
DIR="/home/lehrer/"
chattr -i "$file"
done
chmod +x clean.sh -
. clean.sh
Investigation
We use the so-called ‘immutable bit’ on folders containing exam results to prevent students from deleting them and to ensure that the results are always saved. Originally this was also enabled for teachers, but this caused Bug 57661. We have fixed this by removing the entire ‘Immutable’ routine for Tutors.
The problem now occurs when an environment has the Immutable bit set but not removed (for example, a system crash during the exam has left the system in an inconsistent state) and then upgrades to the latest version. As the routine is now completely missing, the bit is neither removed nor managed in any way.
