UCS rejected
<NORESYNC=broken file:1502796706.650481.swp>;unknown
S4 DN: <not found>
Filename: /var/lib/univention-connector/s4/.1502796706.650481.swp
/usr/share/univention-s4-connector/remove_ucs_rejected.py "<NORESYNC=broken file:1502796706.650481.swp>;unknown"
Maybe this entry blocks the processing of following rejects
With UCS5.0-3 this seems temporary not to work anymore. Bug 55774 (Fixed 5.0x608 and 5.0x609) You can try to check the database instead.
sqlite3 /etc/univention/connector/s4internal.sqlite "select key from 'UCS rejected' where value='<NORESYNC=broken file:1502796706.650481.swp>;unknown'
this should show the picklefile
To remove it you have to stop the connector:
systemctl stop univention-s4-connector.service
sqlite3 /etc/univention/connector/s4internal.sqlite "delete from 'UCS rejected' where value='<NORESYNC=broken file:1502796706.650481.swp>;unknown'
systemctl start univention-s4-connector.service
Optional
In certain cases, it may be necessary to remove or relocate the rejected files from the path and then re-execute the remove_ucs_rejected.py script to clear the S4 rejections and resolve the issue.
rm -rf /var/lib/univention-connector/s4/.1502796706.650481/usr/share/univention-s4-connector/remove_ucs_rejected.py "<NORESYNC=broken file:1502796706.650481.swp>;unknown"
univention-s4connector-list-rejected
UCS rejected
S4 rejected
There may be no rejected DNs if the connector is in progress, to be
sure stop the connector before running this script.
