Problem: UCS App Installation Fails Due to Redirect to External S3 Endpoint
When installing applications from the App Center in UCS, downloads from the artifact registry may fail.
The domain artifacts.software-univention.de redirects blob download requests to an external S3 endpoint (s3.de-west-1.psmanaged.com).
In environments with restrictive firewall or proxy configurations, this redirect can be blocked, resulting in installation failures.
curl https://s3.de-west-1.psmanaged.com
<!DOCTYPE html
	PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
	 "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" lang="en-US" xml:lang="en-US">
<head>
<title>Web Security Gateway</title>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
</head>
<body content-type="text/plain; charset=UTF-8">
<span id="redir_msg" style="display: none"><p>Redirecting you to Web Security Gateway.</p></span><script language="JavaScript" x-barracuda="1">
if (0) {
  document.write('<div style="border: 1px dotted red; padding: 2px; font-family: sans; font-size: 12px; color: black; background-color: white">This portion of the requested page has been blocked.
<skip>
Investigation
When pulling container images from:
https://artifacts.software-univention.de
the registry could responds with an HTTP 307 Temporary Redirect pointing to:
Example output:
[fabian@svalka ~]$ curl -sk -H "Authorization: Bearer $(curl -sk "https://artifacts.software-univention.de/service/token?service=harbor-registry&scope=repository:ucsschool/ucsschool-kelvin-rest-api:pull" | jq -r '.token')" https://artifacts.software-univention.de/v2/ucsschool/ucsschool-kelvin-rest-api/blobs/$(curl -sk -H "Authorization: Bearer $(curl -sk "https://artifacts.software-univention.de/service/token?service=harbor-registry&scope=repository:ucsschool/ucsschool-kelvin-rest-api:pull" | jq -r '.token')" -H "Accept: application/vnd.oci.image.manifest.v1+json" https://artifacts.software-univention.de/v2/ucsschool/ucsschool-kelvin-rest-api/manifests/release3.1.0 | jq '.layers[0].digest' -r) -v
< HTTP/2 307
< date: Fri, 23 Jan 2026 08:38:20 GMT
< content-type: application/octet-stream
< content-length: 0
< location: https://s3.de-west-1.psmanaged.com/artifacts-software-univention-de/docker/registry/v2/blobs/sha256/dc/dc0decf4841d19b14e836c2d82bd5cb9540fb5e0d1359549ca243f49036557e9/data?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=...
This redirect is expected behavior.
s3.de-west-1.psmanaged.com is the S3 object storage backend of Univention’s hosting provider.
Root Cause
Firewalls, proxies, or web security gateways block outbound traffic to:
As a result, container image layers cannot be downloaded.
In some environments, the proxy returns a web filtering page instead of the expected blob content.
Example test:
Blocked response:
This confirms that the request is intercepted by a proxy or firewall.
Related Bugreport: 58990
These domains must be allowed in the firewall and proxy configuration, if the UCS is behind a proxy:
updates.software-univention.de
appcenter.software-univention.de
license.univention.de
Ensure:
  • HTTPS (TCP/443) outbound access is permitted
  • SSL inspection does not break registry authentication
  • No content filtering interferes with OCI image downloads
Verification
Test connectivity using verbose curl:
curl -v https://updates.software-univention.de
curl -v https://appcenter.software-univention.de
curl -v https://artifacts.software-univention.de
curl -v https://s3.de-west-1.psmanaged.com
curl -v https://license.univention.de
Expected result:
  • Successful TLS handshake
  • HTTP 200/301/302 responses (no proxy block page)
  • No Web Security Gateway HTML output
Recommendation
Customers operating UCS in restricted enterprise environments should:
  • Explicitly whitelist all required Univention infrastructure endpoints.
  • Review proxy policies for container registry redirects.
